跳转到主内容
问题已关闭
MacBook boot not working, fans active
Hi all,
I have an old broken MacBook here. When I hold down the power button I do here the fans starting to turn, the hard disk unlock (or at least some sounds) like it's booting up but the screen stays black, I cant eject a disk, the shift key light can't be turned on and no boot sounds is heard. After 10 seconds the sounds die down and goes to a minimal fan speed like it's on sleep.
I've tried to boot it while holding shift and also the PRAM reset (option, cmd, p and r).
Any ideas what could fix this? Is it a common problem? Something seems to work still so I have hopes of fixing it.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Can you give us a history on the machine with emphasis on any video issues or screen artifacts?
完成的
@Mayer Thanks for you reply. There isn't any history of repair or previous problems. It was put into sleep in the evening and the morning after the problems started.
完成的
添加一条评论
1个答案
0.0001% chance it is RAM, 99.9999% chance dead GPU. If this is NVIDIA replace with G84-603-A2, 128 bit, NOT cheap 64 bit remarked junk. If this is X1600 based just toss it in a bin there are no new chips for those and the old VRAM dies when you heat the board to replace the chip.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 159
