跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
Auto Brightness doesn't work after replacing the screen.
I bought the Screen with everything included. I followed the guide to the letter. Today I noticed that the auto brightness feature doesn't work anymore. I can adjust the brightness manually but not automatically. The front camera works, and I know the sensor works because when I am on a call the screen turns off when close to my ear. Did I do anything wrong during installation or is my replacement part faulty?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
Hi Giancarlo,
You need to disconnect then re-seat the screen assembly.
If this doesn't help, you need to get a new complete front camera flex cable (or even much better: get the one from your old screen), and install it using this guide.
If the above doesn't help, let us know, to explore other causes such as problems with or damage to the logic board during previous manipulation.
Replace a front camera and sensor cable compatible with the iPhone 5 smartphone. Includes the front facing camera, secondary microphone, ambient light and proximity sensors. Part #821-1449-A, 821-1449.图片
产品
iPhone 5 Front Camera and Sensor Cable
这个答案有帮助吗?
得分 4
1条评论:
Hi, and thanks to all of you. I switched the cable from my old screen and now the new screen works perfectly. Problem solved.
完成的
添加一条评论
No the sensor does not work. Proximity and ALS are two separate sensors.
You either tore the flex cable, damaged the logic board or didn't connect the connector well.
这个答案有帮助吗?
得分 1
1条评论:
Ok so in your opinion what do I need to do now to fix it? Get another screen?
完成的
添加一条评论
添加你的答案
giancarlolugo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 7,652
