跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
When iPhones battery drains to nothing, I cannot charge it
Hi.
Got a problem with two iPhone 5
When iPhones battery drains to nothing, I cannot charge it. If the battery has power, it charge normally. Tried to change battery and dock connector, but its the same...
Can anyone tell me where the problem might be?
Do think it´s the mother board, but where on the motherboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Alex,
It is most likely the U2 IC that is causing this issue. Check out an older question which is relevant in this case:
iPhone 5 battery replacment failed, due to U2 IC chip malfunction..
Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 132
