iPhone 5 battery replacment failed, due to U2 IC chip malfunction.
I have realized that when the Iphone 5's U2 IC chip is not working properly, once the battery is 100% dead it is toast. When replacing the battery with a new one the phone works fine, until it has completely drained again. If the phone is on it will charge just as long as it does not 100% deplete its battery life. My question is what happens to the battery that it can never work again? Can I recharge this 100% depleted battery another way, then reinstall as a new fix, instead og buying a new battery every time?
9条评论
Why not go somewhere that you can replace u2?
It's not much easier? :)
由 Fixmart Laboratory 完成的
Just for your knowledge ...
Component u2 that is not good cause high current consumption, overheating.
Difficult and uncomfortable to use the phone like that.
If you do not correct it, instead of buying batteries is better for you to buy an old Nokia phone, that will cost you as one battery for the iPhone 5, and Nokia do not have u2 and the battery will stay weeks LOL :)
send my the iphone i will send you 10 NEW Nokias!
Do you know where I can replace the U2 IC for the iPhone 5 in Europe ?
If not, Do you have a step-by-step review to do this reparation ?
Thanks
由 majd ghazaleh 完成的
Hi, I can replace u2. That's what kind I usually do. Where about are you if I can help
由 aqi 完成的
Can we replace the ic board in iphone 5s. The shopkeeper is fooling me from 2 months saying we are not getting the matching IC Board. Is it true apple has such unmatching ic board issue ?
Please help me with my question !!
由 Dinesh Jain 完成的
显示更多的4条评论
