跳转到主内容
The Iconia A110 is an Android tablet released by Acer in October, 2012. It features a MicroSD slot, HDMI port, a 7" multi touchscreen display, and a 2.0-megapixel front camera.
问题已关闭
USB device not detected on pC
I've got 2 Acer Iconia tablets A110 and one is detected when I connecte it to PC but the other one is NOT detected. The conditions are identical but the results are NOT while connect them to PC. Might anybody help me with a solution? Thanks very much
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Are they running android OS?
完成的
Josh, Yes tablets run android OS
完成的
添加一条评论
2个答案
最有帮助的答案
Make sure USB debugging is turned on, it maybe a setting. You can find the USB debugging option in your settings. Depending on what Android OS your running, its either under applications or developer options.
Check the device that connects settings, then check the other device and make sure they match, that's a quick way to rule out a software glitch.
这个答案有帮助吗?
得分 1
添加一条评论
OK so we are clear here: You have to of the same Acer Iconia tablets using the same USB cable one is able to be seen by the PC and the other not. Both are working and both have the same OS revision.
Try this, with the one that is working leave it plugged in and then using a second USB cable connect it to the second tablet. Is it able to be seen then? If not I suspect the USB port on the tablet is bad.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,018
