跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Device lost 20% charge / hour, completely dead after battery swap.
Hi guys!
I'm a repair guy, been fixing smartphones for around about 2 years. Have seen quite some weird stuff happening, but this one has got me desperate.
Last week, I received an iPhone 5S that couldn't quite keep its charge anymore. It lost about 20% of its charge per hour.
The obvious next step was for me to replace the battery. Sadly, that didn't fix the problem. The new battery still drained like !&&*, leaving me to think there was a short circuit somewhere.
Having seen some faulty camera's, dock connectors etc causing the same symptom, I started taking apart the device and left it running with camera's and dock connector disconnected. Sadly, again, resulting in the same weird battery drain. So I put the device back together and shut it down.
Today, however, I wanted to do some more testing, but noticed the device wouldn't boot up anymore. Not at all. I left it charging for hours, but the screen remained blank. All connectors and screws were in place.
Later on, I measured the battery voltage, which was sitting at 2.7V (instead of 3.8V), staying at this point, not wanting to charge any higher at all.
With currently no other battery to test with (the previous one died in the replacement process), I don't know what to do anymore. Since the device won't give a sign of life anymore, even when plugged in without a battery (the Apple logo should appear), I fear it might be toast.
Does anyone have any experience with this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
why did you leave the phone on whilst removing components?
这个答案有帮助吗?
得分 0
1条评论:
I didn't. I turned it off, removed battery and some components, then plugged the battery in.
I've seen some faulty components (dock connectors, camera's etc) cause the battery to drain extremely quickly, so my goal was to find wich one was causing the problem.
Under no circumstance did I leave the power running while removing components.
完成的
添加一条评论
添加你的答案
Laurent Loots 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 297
