跳转到主内容
加入维修社区 - 创建账户
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
MacBook won't boot after memory upgrade
I have a mid 2007 13 inch Macbook that won't boot after installing an additional 1 GB of memory (for a total of 2). I tried removing it and putting back the 1 gig again and it still won't boot. The battery lights indicate a full battery but the magsafe light is amber when connected. I tried resetting the SMC and the Pram without luck. There is no sound of fan, etc and no lights anywhere.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
Did you only remove the same module you put in, or did you try removing both? Are you sure you follow good ESD practices?
完成的
添加一条评论
1个答案
If the RAM is wrong type it won't work- we need more info than just the chip size (Speed, Timing, Voltage, Channel) Does the old RAM still boot the box? If not might you have damaged the risers?
If this answer is acceptable please remember to return and mark it accepted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Henry Morgan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 139
