跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
问题已关闭
MacBook wont go to sleep when lid is shut?
Hi guys i've been looking through your guides trying to find a glimpse of the possible location of the reed switch on the 4th Gen MacBook late 2008 2.4 Ghz model but i cant find anything. Can any of you suggest on where would that be located so i can fix it myself? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I just checked on my 2.4 from 2008 by slowly sliding an extra HDD down that side and it should be right next to the left of the function key. at least thats where the HDD was when it went to sleep and then woke up once i moved it from that spot
这个答案有帮助吗?
得分 0
添加一条评论
according to some research i just did its on the battery cable
这个答案有帮助吗?
得分 0
1条评论:
What do you mean by a extra hdd so should i be able to do that by without opening the case to repair it? thanks
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 1,303
