跳转到主内容
Repair guides and support for external portable storage by Western Digital including the My Book series, My Passport and others.
218 个问题 查看全部
Trying to retrieve information from an IDE drive
How can i put my IDE hard drive in another IDE compatible computer to retrieve the information? I know how to install it into the tower, but i cant see whats on the hard drive. I can also see it on the Device list but dont know what to do after that? Any help??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Was it formatted Mac or PC?
完成的
Its for PC
完成的
添加一条评论
2个答案
已选择的解决方案
Using an external adapter may be the way to go. You can hook it up and plug into a USB port to access it. Here's where and what to get: http://eshop.macsales.com/item/Newer%20T...
这个答案有帮助吗?
得分 3
2条评论:
+ Ralph Use one of those myself frequently.
完成的
Yep, or you could do that :]
完成的
添加一条评论
With IDE, you have to set master or slaves. If the old drive is on the same cable as the new drive, you must set the jumpers on the back of the drive to either master for new one, slave for old one; OR set it to Cable select, in which case, you need to put the new drive on the end of the cable, old drive in the middle cable port.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tristan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 850
