跳转到主内容
Cen-Tech Seven Function Digital Multimeter . Model number 90899.
Why will the dial not move to a new position?
I am trying to turn the multimeter to another mode, in order to test voltage. The dial will not turn, so I cannot switch modes.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
There are a couple of reasons as to why the dial may not be not moving. The dial could be dirty or broken, in this case the dial will need to be removed and either replaced or cleaned. See Dial Replacement Guide. Another possible problem is that the ball bearings that are located below the dial need replacing or lubricating in order for the dial to move. See Ball Bearings Replacement Guide.
Cen-Tech Seven Function Digital Multimeter Dial图片
指南
Cen-Tech Seven Function Digital Multimeter Dial Replacement
难度:
中等
10 - 15 minutes
Cen-Tech Seven Function Digital Multimeter Ball Bearings图片
指南
Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement
难度:
中等
10 - 20 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anna Kihm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 354
