跳转到主内容
Model A1046 or A1095 / 1280x854 screen resolution
How to determine the cause of backlight failure after a drop?
After a drop I have occasional flicker on of the screen but normally nothing except by the DVI out port (which works fine).
How do I identify the component that failed? IE PMU or loose wire or what?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
not sure which cable is inverter and do not see a repair guide....a labeled picture would be a great help to check the connections and lookl for crimps....is there a picture on ifixit? Thanks for the suggestions
完成的
添加一条评论
2个答案
已选择的解决方案
A drop gives a big stress to a machine and could easily damage the backlight bulb if the screen is lightened when the unit is dropped. There's also a stress on the cables passing through the display hinges if the display assembly is open when dropped. Your backlight seems to work OK so I'd check the display cables connections.
这个答案有帮助吗?
得分 1
2条评论:
sorry the backlight does not work except occasionally it flickers on then off, so screen is black 99.99% of time. Screen was off and closed when dropped but impact was on the corner with the power plug but that seems to work fine (orange for charge green for charged up)
完成的
If the screen flickers then it's a good news for the backlight that's probably still working. You will have to open the top case and the display to check the cables and the inverter board.
完成的
添加一条评论
Sounds like the inverter cable is probably being crimped. If you type "inverter" into the search box, you'll find many discussions of similar issues that should lead you in the right direction.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
greg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 718
