跳转到主内容
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
It won't start or turn on
Washer will not start
Kenmore 110
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
2个答案
最有帮助的答案
If your Kenmore 110 Series Washing Machine refuses to turn on, see the Kenmore 110 Series Washing Machine Won’t Turn On problem page for possible causes and solutions.
Check and make sure circuit feeding washer is live try plugging a working lamp into the plug with the washer to check
Update
If the lamp doese’t work go to the inside breaker panel and look for tripped breaker normally it will be a 15amp or 20 amp depending on how the circuit is run
这个答案有帮助吗?
得分 1
添加一条评论
Unplug the machine for 5 minutes to allow it to reset.
这个答案有帮助吗?
得分 1
1条评论:
Mine worked by resetting
完成的
添加一条评论
添加你的答案
gene4unot 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 8,088
