跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
20 个问题 查看全部
Broken home button connector
Hi , i broke the small plastic that connect the home button wire and also crake the small blade. The ZIF connector is broken
what can i do now?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
2条评论
Stuck with the same problem.. Have u found any solutions yet?
完成的
look up onyoutube onhow to replace it, or do as i did, buy a whole new front glass screen that comes with the home button already installed then just plug the new one into the board along with the other two supplied and pree attached cables, peel the backing off the new adhesive and put the ipad back together...you can find complete sets on amazon.com
完成的
添加一条评论
6个答案
已选择的解决方案
If it's just the tab thats broken, you can wedge something like a thin piece of plastic where the tab used to be. This will put the downward force on the connector and make the connection.
If the connector is badly damaged, you would either need to find the part and get someone who can micro-solder to replace it (I did a quick search but couldn't find the part), or you will have to replace the logic board.
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
Hi,
If David's solution doesn't solve it, the connector on the board has to be replaced.
Since it is hard to source a good connector if at all (probably demand is not high enough, so suppliers don't make them/offer them), we choose sometimes to microsolder the connector directly to the board. It's a hack, but it's practical and it works.
这个答案有帮助吗?
得分 5
添加一条评论
Hi, this happened to me too and what I did (and it worked) was cutting 2 (or 3 I for got) small pieces of clear shipping tape just about the size (width) of the cable end. Next, tape these on top of the cable end (not the contact side) to make it thicker, then slide it back into the slot. Make sure it goes all the way in, then secure the cable by taping it to the base . Last connect the LCD cable but don't screw it in yet, then lay the LCD and the digitizer down be careful not to make the home button cable move too much. Turn on the iPad to test.
This solution saved me from a night mare when I saw a YouTube video showing that you have to remove the ZIF connector and solder a new one on.
这个答案有帮助吗?
得分 4
1条评论:
Thank you so much for this. I used to layers of tape and it did the job. You are a life saver my friend.
完成的
添加一条评论
Purchase the replacement cable here. Besides the cable, are you saying the entire assembly is broken?
Replace a home button ribbon cable and internal button switch compatible with the iPad Air 1st Gen A1474 and A1475 model tablet. Part #821-1799-04.图片
产品
iPad Air Home Button Ribbon Cable
$14.99
这个答案有帮助吗?
得分 3
添加一条评论
Or. Just use assistive touch in settings to have a home button on the screen. Home button will work on screen. Not ideal, but it works. I just broke my zif connector in replacing my screen. Will work for now.
这个答案有帮助吗?
得分 2
添加一条评论
Get packing tape cut it to the size of the connection put 2-3 pieces on top of each other depending on the thickness of the tape and that’s all to it it will work perfectly fine
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sultan 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 38
总计 14,711
