跳转到主内容
加入维修社区 - 创建账户
Released June 2011, identified by model number MB870
Why isn't my camera working?
When using my camera, it looks like there is something inside of the phone obstructing the lens. Any tips for a fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Before anything else, you should restart your phone to see if that fixes it. Sometimes all your phone needs is a good restart. If it doesn't you have you will have to open up your device.
Having something stuck inside the lens seems unlikely since the phone is sealed, but it is possible. You want to open up your device following this guide. Once you get to the camera, check to see if there is anything stuck in the case. If there is none, get the camera itself for damage and scratches. If you notice a scratch on the lens, you'll need to replace it.
这个答案有帮助吗?
得分 0
添加一条评论
If there is any particles or dirt that made it's way inside the phone near the camera it can cause it to work improper or give a shadow on pics taken.
I recommend that you disassemble the phone carefully and use a can of compress air that you can pick up at walmart or online. Simple spray the compressed air and it will safely remove the particles that were bothering your camera.
Important that you do not touch the camera circuit it can cause ESD and result in short circuiting the board.
Use ESD strap or grounding equipment when working on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alec Riendeau 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 173
