跳转到主内容
Motorola Droid X2 Rear Facing Camera Replacement
你所需要的
  1. Motorola Droid X2 Rear Facing Camera Replacement, Battery: 步骤 1 中的图像 1,3 Motorola Droid X2 Rear Facing Camera Replacement, Battery: 步骤 1 中的图像 2,3 Motorola Droid X2 Rear Facing Camera Replacement, Battery: 步骤 1 中的图像 3,3
    • Slide the plastic case off of the back of the phone, exposing the battery.
  2. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 2 中的图像 1,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 2 中的图像 2,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Pull up on the red battery release tab and pull the battery out of the phone.
  3. Motorola Droid X2 Rear Facing Camera Replacement, Motherboard: 步骤 3 中的图像 1,2 Motorola Droid X2 Rear Facing Camera Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
    • Be careful to not strip any screws.
  4. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 4 中的图像 1,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 4 中的图像 2,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 4 中的图像 3,3
    • Using a prying tool, snap off the front casing on the top and bottom of the phone.
    • Be careful not to lose the small rubber piece that sits over the microphone.
  5. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 5 中的图像 1,2 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 5 中的图像 2,2
    • Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
  6. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 6 中的图像 1,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 6 中的图像 2,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 6 中的图像 3,3
    • Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
  7. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 7 中的图像 1,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 7 中的图像 2,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 7 中的图像 3,3
    • Using tweezers, remove the white wire at the top of the phone near the camera.
  8. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 8 中的图像 1,2 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 8 中的图像 2,2
    • Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
  9. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 9 中的图像 1,2 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 9 中的图像 2,2
    • Using tweezers, removed the white electrical tape on the motherboard.
  10. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 10 中的图像 1,2 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 10 中的图像 2,2
    • Using the plastic opening tool, lift up to remove the connector.
  11. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 11 中的图像 1,2 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 11 中的图像 2,2
    • Using a pry tool, lift the jawbone connector.
  12. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 12 中的图像 1,2 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 12 中的图像 2,2
    • Using tweezers, carefully disconnect the cable connector by pulling the cable out.
  13. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 13 中的图像 1,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 13 中的图像 2,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 13 中的图像 3,3
    • Use a spudger to disconnect the cable connector.
  14. Motorola Droid X2 Rear Facing Camera Replacement: 步骤 14 中的图像 1,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 14 中的图像 2,3 Motorola Droid X2 Rear Facing Camera Replacement: 步骤 14 中的图像 3,3
    • Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
  15. Motorola Droid X2 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 15 中的图像 1,3 Motorola Droid X2 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 15 中的图像 2,3 Motorola Droid X2 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 15 中的图像 3,3
    • There should be jawbone connector here. However it was broken on this particular device. Lift it up using a pry tool.
    • Using tweezers, remove cable from motherboard.
结论
Aaron Mak
于10/29/14注册
658 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-3, Miles Fall 2014 UMass Dartmouth, Team 4-3, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G3
3 名成员
创作了8篇指南
一条评论
how do u get it back on when it dose not come back on
brianna
Brianna Dittbrenner - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 12
总计 274
