Need help identifying component.
Hi, i have recently got hold of a late 2011 Macbook Pro but id doesn't appear to turn on. I have found on the board that a component was damaged. Can anyone please identify the circled component?
Thanks in advance.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
Sam Taylor, that is reference designator C6603 which is a 100UF 6.3 V 20% Tantalum capacitor in a AL1 case. this capacitor is part of your audio speaker amp circuity, should not have anything to do with starting up
这个答案有帮助吗?
按维修分数 1
评论:
disconnect the top case ribbon cable and the battery, connect the charger to the MBP and check if you get 3.42 volts on one of the two power pads. Do you have a steady green light on the magsafe light ?
Fantastic thank you very much :)
添加一条评论
添加你的答案
Sam Taylor 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 64
