How do I print without colored ink?
My printer will not print because I am out of colored ink. I just want to use the the printer to print in black and white, how do I fix this?
If you are out of colored ink:
Hold down the resume/cancel button. The resume/cancel button is the smaller button below the power button, on the right side of the front of the printer. Press for 10 seconds. You can now print in black ink.
If the printer is completely out of ink, you will see the alarm lamp, to the left of the resume/cancel button, flash orange four times to indicate the ink supply is low. You'll need to replace the ink cartridges.
For more information, please refer to this device's troubleshooting page.
这个答案有帮助吗?
Thank You! So simple and it worked!
thannks, didn't work for me. I must have a different canon mx300. There is no cancel resume button
Thank you!! I pressed the STOP button for 10 seconds then printed normally.
Worked on my Cannon Pixma iP7250 Thanks! :-)
THANK YOU - you are my hero :D
Inkjet printers do not have white ink. So printing only in black and white is not possible. The printer mixes the black ink with color in order to produce different gray values. The reason why inkjets and color laser printers cannot print when there is an empty or missing cartridge ia due to the fact that everytime you power up the printer, it will initiate a charging and head cleaning cycle. Running this cycle with an empty or missing ink cartridge would quickly cause irreparable damage to the print head . This is why a printer will not work in this situation. When you press the button for 10 seconds, then it may work for a short time (probably there is a little ink still in the cartridge). If you truly want only black and white printing, and not have to spend money on color inks that you will "never" use, then your best option is a monochromatic laser printer.
这个答案有帮助吗?
Thanks, this is the very first time I've found a satisfying answer to why my printer is still consumming colored ink when printing in gray levels.
This is completely bulls**t! The white parts coming out of the printer...is the paper itself!
Then what is gray? - Well that's just tiny dots of black on the white paper, creating an illusion that makes it look like it's gray. However in a microscope, it would look like a pattern of black dots.
Also, if you mix colors of light (lightwaves), you get white, which is why a rainbow can be produced from white light.
However when it comes to colors of pigments/inc, you CAN'T mix them to get white. The colors will simply get darker, because pigments ABSORB light.
This is bulshit. The paper is white.
Your bubble is very limited. Were you just born? Every other printer I have had or used (dozens over the last 30 years) works fine printing or copying with empty color cartridges. Sometimes I want color, sometimes I don't need it. Sometimes I want it, but if it's out I can make due with b/w - and btw, gray is just less black ink. Some documents don't even need grayscale because it is all black text! I usually change my documents to dark gray to save black ink - works great. I just needed 5 more copies of a handout for a class today and 5 of 30 kids didn't get one because the printer is being stupid.
That is actually absolutely wrong. The printer uses the color cartridges to get a more appealing color of black. It creates gray by spraying small dots instead of a continuous area so that you see the white of the paper shine through,
The reason that they won' t print without a color cartridge is a combination of greed and avoiding complaints that the black doesn't look right or another color is missing
To print black ink only
that’s of Canon website They also warn that a small amount of colour ink will ALWAYS be used to properly maintain printer heads. This is what the first guy above was saying before others chimed in calling it BS
also the two black cartridges perform different tasks and can’t be used in the others place . It must be replaced
这个答案有帮助吗?
My mg 3670 is flashing 5 times with and without cartridges. What can be the solutions? Plz reply....
This works for ip3600 series canon printer. But it is troublesome cause it needs to turn off the duplex print every time for gray scale printing that do not use color catridge. Duplex print is required when need to print on both sides. of paper
if you replace the black ink and not the color should my cannon mx340 print. the color is empty but still in the printer
这个答案有帮助吗?
im out of black ink. im using canon pixma mp287. how to print using color only ink?
这个答案有帮助吗?
can I print on a cannon mx-490 printer without color ink? I use black and white always, but it won't print without color.
这个答案有帮助吗?
Find the "ink set" setting on your printer configuration and set that to "black"
Hi mine is mg 2540S , that orange is flicking about 3 times . But still refuse to print even on black only . Maybe they are both empty .
这个答案有帮助吗?
I did change the settings to only black already...
这个答案有帮助吗?
Didn't work. This stupid printer still searches for Color cartridge But i dont have it. I only have black color catridge.
Hello
I have a Canon Pixma MX885, I have no print head, it is HS. Also, I would like to know if it is possible to scan to the PC and fax anyway. If yes, how ?
Thank you
这个答案有帮助吗?
Your thermal print head is used to heat and spray ink on paper. It should not prevent you from scanning or faxing. You should be able to scan your document into your 1. printer or 2. a file in your computer and then 3. fax it where ever you want. You may need to find where your operations instructions for the printer are stored. File folder Icon at the bottom left on most Windows systems will lead you to your printer device or simply go online to Cannon , find and download operations instructions for your model.
这个答案有帮助吗?
In case you didn't read, Problem was already solved 5 years ago.
The red "cancel" button was the answer the questioner needed, as it is the button used to remove warnings.
My printer is refusing to do anything until I put in colored ink.
The color cartridge is only required to print white. If you’re printing on white paper, you will be able to get by just fine with a black cartridge and an empty color cartridge.
The trick is in finding a printer setting called “Ink set” and set that from “Both” to “Black”.
”Both” = Mix color and black cartridges to produce grayscale output
”Black” = Only use black cartridge to produce grayscale output
This setting is what your printer uses to determine color mixing strategies for monochromatic/grayscale printing.
Without a color cartridge in use at all, you won’t be able to print a proper white by mixing R + G + B, but if you’re printing on white paper, this doesn’t matter at all.
这个答案有帮助吗?
Printing Without Colour Ink is Know as grayscale Printing , people Often confuse it With No Ink Printing But its Not like that Now to Do that Please Follow Given steps-
it should Fix the issue
这个答案有帮助吗?
Canon mg2920
Can't get android to connect and there are 3 orange lights blinking. Color ink is probably out but I placed a new black ink as I only want to use black to print a document. I can't figure out anything, I'm getting very frustrated.
这个答案有帮助吗?
过去的24小时: 184
过去的7天: 1,187
过去的30天: 5,696
总计 259,075
Thanks. A simple answer to a very frustrating problem. Couldn't find anything in the manual or printer instructions that mentioned this.
由 J PR 完成的
Do you have to have both cartridge inside color and black. Or can you leave one cartridge out
由 Carolyn 完成的
i just bought a canon pixma mg2522 and mine wont print either i only purchased black ink with it not color . returned it thinking something was wrong with it and the second one wont print either. id like to know the same thing carlyn wants to know. do you have to have both ink cartridges in place to print anything or should it work with just black?
由 Barbara 完成的
I left the empty color cartridges in my Canon printer and just refilled the black tank cartridge. Hold the stop button for ten seconds....don't have a stop button? how about a cancel button? Maybe yours has a yellow triangle button. A computer analyst tries every key to determine its function. Be creative.
由 David Luna 完成的
"Hold the stop button for ten seconds....don't have a stop button? how about a cancel button? Maybe yours has a yellow triangle button. A computer analyst tries every key to determine its function. Be creative."
THIS WORKED FOR ME!!!! Thank you!!
由 syb3 完成的
显示更多的26条评论
