跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Touchscreen randomly not functioning after unlocking?
I replaced my iPhone screen today, however I am having some issues with the touchscreen.
When I am using the phone, the screen stays responsive and runs with no issues. However, if I lock my phone and wait for 20 seconds or so, the touchscreen will indefinitely not work upon unlocking the device-despite the actual LCD still functioning perfectly.
However, if I lock and then unlock my phone again immediately after this, the touchscreen will work perfectly without any issues; until I leave the phone locked for another 20 seconds etc...
So far I have reconnected all the flex cables between my new screen and the phone twice (no difference seems to be made) and I have done a hard/soft restart and a reset of my phone.
I hope that anyone could shed any light on this being either a software or hardware issue; as although it seems to be software related, this problem only occured after replacing the screen. No movement of the phone is needed for the touch screen to work/stop working, which just generally confuses me!
Thanks very much in advance for any answers! (:
(Sorry about my avatar... linked to my gaming accounts!)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Did anybody find any solution for this? I am having the exact same issue after replacing the screen.
完成的
Hello , Does anyone has solution to this problem? I am having exact same issue after replacing the screen.
完成的
添加一条评论
5个答案
最有帮助的答案
It's a faulty screen seen this issue before
这个答案有帮助吗?
得分 1
添加一条评论
I've seen this problem once, faulty LCD.
Confirm by using your old LCD to test
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem with my iphone 5 after replacing battery..
这个答案有帮助吗?
得分 0
添加一条评论
hey Matt, how did you resolve your issue?
这个答案有帮助吗?
得分 0
添加一条评论
put your phone battery to drain to zero... and then put it on charge after sometime .......... it works for me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 2,896
