跳转到主内容
加入维修社区 - 创建账户
2011 年 9 月上市。屏幕:800 x 1280 像素,9.4 英寸。芯片组:1GHz Nvidia Tegra。500 万像素摄像头。搭载 Android 操作系统,v3.1 (Honeycomb),可升级至 v4.0.3 (Ice Cream Sandwich)
WIFI does not work
Hi,
I can't connect to the wifi at home, it detects the signal but it does not connect to it. It thought it was my wifi's home, but at work it happens the same. I also went to another person's house and the wifi does not work.
I put the password again, disconnect and connect the wifi, but nothing happened.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
polharder, has it ever worked for you? Did you change anything in your settings lately
由完成的
添加一条评论
1个答案
已选择的解决方案
Try going to an open WiFi location (an AP without any security password). See if it can connect to it (altering your AP settings; going to McDonalds or Starbucks Coffee house etc...)
If it does work then you'll need to check the case of the password as upper & lower case are different here (even unicode characters). Also make sure the password is not overly long as some devices can't parse the key longer that 10 digits/characters.
Next check what security option you are using on the AP and make sure your device can do it. As an example some older devices can't to WPA 2.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
polharder 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 35
总计 586
