跳转到主内容
The current line of iPod touch comprises seven (7) different generations.
2619 个问题 查看全部
Having trouble unscrewing screws?
Is there another way to unscrew the screws? Some of the screws were screwed in with a electronic screwdriver (not sure if thats right or not) but i'm having trouble getting them out to replace something. what other ways could i unscrew them?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Make sure you use a quality metal screwdriver and that the bit fits all the way in the hole or it will strip the screw head. Press down on the driver while turning it.
这个答案有帮助吗?
得分 2
2条评论:
What happens when its striped?
I got most of them off, just two left...
完成的
完成的
添加一条评论
添加你的答案
shadowfox00101 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 2,988
