跳转到主内容
加入维修社区 - 创建账户
This device is part of the second wave of Polaroid's 600 series cameras that were developed between the 1980's and 1990's. It would instantly develop the film in about three minutes and the battery was integrated into the film pack.
Why aren't my pictures developing?
I am taking pictures and the flash is engaging. The camera ejects a picture, but the picture isn't developing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 26
7条评论
I got one for christmas, and i tried taking 3 pics, none of them devolped, it is kinda cold in my room does that have to do with it
完成的
how did you fix it? bc mine has that problem too & idk if its broken
完成的
I got a polaroid 7's camera and when I take the pic and print it I let it be for a while but nothing shows up
完成的
i got a polaroid 10 cameraand it wont
show up
完成的
I have the instax mini 7s and I took two pictures with the indoor setting and one with the fine setting and they all came out blank
完成的
显示更多的2条评论
添加一条评论
17个答案
已选择的解决方案
It is always possible that the temperature is not ideal for the picture to develop. If you are using the film originally designed for the camera then the film is really old and not likely to work. If you are using the Impossible film then the film is very experimental and very sensitive to its surroundings. You don't want it to be too hot or too cold. In the directions of the film is says that at an ideal temperature of 70 degrees Fahrenheit it will take the pictures about 10 minutes to develop.
Here are a couple other resources for troubleshooting similar cameras that might help:
Polaroid Onestep Close Up Troubleshooting
Instax Mini film not developing
这个答案有帮助吗?
得分 13
添加一条评论
I just took one with the flash and it printed fine, then I took 2 more right after and nothing is showing
这个答案有帮助吗?
得分 6
3条评论:
That’s exactly what happened to me I just got the camera and film today.
完成的
Flash needs to be on, unless your environment around the subject is extremely lit up
完成的
i got mine today and i printed only 7 and the other 6 did not work
完成的
添加一条评论
everytime i use the polaroid the pictyre will came out with nothing. It is not developing... I need help
这个答案有帮助吗?
得分 3
4条评论:
Usually for me, it takes about 3 minutes max for my Instax 8 Polaroid pictures to develop. However, this time I have taken the picture and 15 minutes later it's still not developed. I have taken three today and two have turned a peach colour and no other shapes are formed- the entire picture is peach and my third one has some spots of the picture on it but it still has not fully come through within 15 minutes. Help!!
完成的
Well maybe you are taking the picture in the dark, because if you take it in the dark it will not show up
完成的
I just started im new i took one with my dog and mine is a black pic it wont show up
完成的
Your film could have possibly expired, unused film even in it's sealed packaging won't last more than usually 5 to 10 year's. If you try to use film 5 to 10 year's after it expired the photo's will either be very faint and or tingish/orangeish or absolutely nothing at all. You can buy new film at Polaroid Immposibles.Com or at Target Department Store's in the Electronic's department but it's a little expensive though.
完成的
添加一条评论
If it is not working , it is probaly to hot. Try puting it in the fridge for NO MORE then 1-3 minutes.
这个答案有帮助吗?
得分 2
添加一条评论
You have to let it in the dark so it can develop at least 5 to 10 minutes if not developing shake it for 10 seconds and then put it back in the dark for 5 to 10 minutes if not developed by then shake it more for 10 minutes and if not developed then leave over night
这个答案有帮助吗?
得分 1
3条评论:
it does help by the way
完成的
Don’t shake it! Shaking it won’t do anything. If you shake it the photo will not come out.
完成的
Shaking it will cause spots in the picture; if you shake it too much. If you do a little its fine (it wont really effect it), but shaking hard or for too long will ruin the image and wont develop clearly.
完成的
添加一条评论
Check your rollers. At the bottom of the Polaroid film is the big white rectangle, this is where the chemicals are stored. If your rollers are dirty or glazed then they won't spread the emulsifier correctly and your prints won't come out. Open your camera with no film in it, and clean the rollers with rubbing alcohol, the stronger the better. Use cotton swabs. Chemicals get all over them and gum them up. Clean them and check that they are rolling well. Make sure your film cartridge is well seated and then try again.
Don't shake the film it doesn't do anything.
这个答案有帮助吗?
得分 1
添加一条评论
It has happened to me to. Its Okay Guys! Calm Down. The Film Is Probably Older Than The Other Films You Have. Or Maybe Its Just Malfunctioning. Y'know You Can Just Get Another Pack. I Got Another And It Worked Again. But If You Dont Want To Waste Money, Try Other Methods To Fix Your Problem! Okay Thats It.
这个答案有帮助吗?
得分 0
添加一条评论
The same thing is happening to me. The film I have is brand new, and I'm at the beach in GREAT lighting trying to take pictures of myself, the sky, and the water. Nothing is showing up and I've taken 4.
这个答案有帮助吗?
得分 0
1条评论:
same exact thing happened to me, but the film isnt even coming out. I hear the shutter and the flash is there, but the picture just doesnt come out
完成的
添加一条评论
Same for me. Probably cause i ran out of film in 2001. Check if you ran out of film
这个答案有帮助吗?
得分 0
1条评论:
the film is brand new
完成的
添加一条评论
Mine is showing white but no picture I took it a few hours ago
这个答案有帮助吗?
得分 0
2条评论:
mine also I dont know what tio do... But it is over 70 degrees and i dont know if that has to do with anything someone help I just got it yestrday
完成的
The same thing happened to one of my films but of you take another one it should show if that’s the case
完成的
添加一条评论
Using the Polaroid original film it can take up to 15 minutes for a film to develop properly. Once you’ve taken a picture immediately put it somewhere dark as they are still very sensitive to light for a few seconds. Check it after a few minutes. NEVER SHAKE THE PICTURE!!!
If the pictures are blank it could be that the rollers in the camera have become loose so aren’t properly rupturing the chemical tab, this will normally result in a kind of yellowy square where the picture should be.
If it’s all white try using the expose slider on the camera to darken the next image.
这个答案有帮助吗?
得分 0
1条评论:
My phone picture are not coming out in colors just a fade
完成的
添加一条评论
This same thing happened to me… Everyone told me to shake it and leave it in the sun. Don’t do that! That will make it too hot. Instead, leave it facing down in a dark, room temp room and it should develop. If still not working and it’s the first pic in that film cartridge, it might be because the company buts a black starter to make sure your camera is working properly. If it is the first pic and the tester doesn’t come out, than you might have to open the back of your camera (where you place the film) take out the film (if you have in already) and you shall see a little rectangle. If the rectangle is dirty, simply add some baby oil on a Cotten ball and wipe the rectangle gentally . Please comment if none of this works and I’ll do some research.
这个答案有帮助吗?
得分 0
1条评论:
I mean at leave overnight and rubbing alcohol not baby oil
完成的
添加一条评论
You have to remember that once it ejects the film cover after you have I started a new film pack, you CANNOT open the back cover (the place where you put the film) again because once the film cover is opened the photos are vulnerable and if they are exposed to any light before you have used them for a picture, all of the film will be ruined and unusable. Hope that helps.
这个答案有帮助吗?
得分 0
添加一条评论
you have to wait about 10 minutes for the picture to fully generate. Some people say that heat light and shaking it can help this situation.
这个答案有帮助吗?
得分 0
1条评论:
How old is your camera my fun comes out in like 30-40 seconds
完成的
添加一条评论
It'll take a few minutes to develop
这个答案有帮助吗?
得分 0
添加一条评论
please someone help i took a pic and set it down then put it in a dark place and black dots are appering help i have wasted 8 film and i dont want to waste them plese someone help if you helpthat would really make my day
这个答案有帮助吗?
得分 0
添加一条评论
It seems that this is an all too common issue and that means fujifilm needs to do something to fix this huge problem!!!
这个答案有帮助吗?
得分 0
1条评论:
Most of these posts are about vintage Polaroid cameras and Impossible Film.
完成的
添加一条评论
添加你的答案
Tyler OBrien 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 58
过去 30 天: 453
总计 209,906
