跳转到主内容
加入维修社区 - 创建账户
于 1997 年秋季之前发布,型号为 RM318PA
Why does the projection clock "on" button keep turning off?
Whenever I turn the projection clock button to the "on" position, it moves back to the "off" position and will not stay on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
After some research, I discovered that the unit needs to be reset.
Resetting process:
Remove batteries and disconnect adapter for 15 minutes.
Reinstall batteries and reconnect adapter.
Hold reset button for 5 seconds located in the battery compartment or on the back of the unit.
(A paper clip or pin will be needed to fit into the hole for the reset button.)
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Kathy,
Sometimes the on/off switch can get a bit loose and you might need to snap it back in place. See the guide linked below!
Oregon Scientific RM318PA 电源开关更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kathy Rowley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 685
