跳转到主内容
加入维修社区 - 创建账户
The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
Screen Issue on xperia z
My phone is experiencing a problem that its screen sometimes goes off but a little dim white light appers..After sometime its screen automatically start show everything.I want to know that whether its LCD should replaced or connecting jack of lcd is loose.this problem has occured many a times.Please suggest a solution to my problem.
had it been a issue of screen damage then it would not work after sometime on its own
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
If you don't believe it's the result of dropping then I'd power the phone off, restart and see if the issue recurs. Try also a software update. If these things don't fix the issue then you will have to replace the screen/check screen connection
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the reply.
完成的
添加一条评论
incoming calls I cant answer?
这个答案有帮助吗?
得分 0
添加一条评论
is it the auto adjustment which you turn on from
SETTING->DISPLAY->BRIGHTNESS?
therefore light source will affect the display brightness accordingly...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cooldudenitesh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,007
