跳转到主内容
Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
64 个问题 查看全部
问题已关闭
Can these burn CDs?
I have a 300 mHz iBook clamshell running OS 9.1 for my older apps. Is the drive capable of burning CDs? I have added Apple Disk Burn to the utilities, but when I pop in a blank CD, it is unreadable.
Update
Thanks for the suggestions. I actually bought a thumb drive (Sandisk) - it fits into the slot, but it won't mount on the desktop. The specs for it said that OSX was required, but I don't see what the difference would be. I have also read that I don't need to download a mass storage driver, as it came with the OS (9.1). I'll be trying an ethernet connection next. Any other suggestions regarding the thumb drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
8个答案
已选择的解决方案
Another thing to note is that similarly to the USB ports of the iMac G3, the iBook clamshell will not be able to fit any USB Flash Drives because they are too wide and the case design of both of these prevents anything that is wider than the port from fitting. I have an iBook clamshell (as well as an iMac G3) myself, and the way that I've gotten around it is by using an extremely short USB Extension Cable, plugging one end into the Mac and the other into the flash drive.
This is actually the one that I ended up getting: http://www.shaggymac.com/index.php?main_...
As for other Macs and Mac hardware with this problem, check this Apple Support article: http://support.apple.com/kb/TA22788?view...
Also, if you'd rather just be able to burn CDs, then you can upgrade your iBook's optical drive here: http://www.wegenermedia.com/ibookcdrwhom... (although that kind of ruins the look).
这个答案有帮助吗?
得分 1
1条评论:
Many USB flash drives do fit -- I've actually got one in a Clamshell right now. But you're right, it's a tight squeeze and probably impossible for a lot of them without an extension.
完成的
添加一条评论
最有帮助的答案
According to Mactracker, these computers all had CD-ROM or DVD-ROM drives -- no disk burning capabilities, unfortunately.
If you're trying to move large amounts of data off of the machine, an ethernet network may be your best bet, since it appears you have the non-Firewire model and the USB on these machines is only 1.1.
这个答案有帮助吗?
得分 1
添加一条评论
If you're just looking to get the data off the computer, a USB thumb drive might be a good option. It will be slow to copy, because, as Mister790 pointed out, it's only USB 1.1, but you can always just start it going and come back an hour later.
A lot of USB drives are bigger than the hard drives on Clamshells, which is pretty bizarre to think.
这个答案有帮助吗?
得分 1
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
Your best bet is buying an external burner/optical drive, not only will it have the capabilities and not be old, but it'll be way faster than the built in one. Plus, you'll probably get DVD capabilities with that.
这个答案有帮助吗?
得分 0
添加一条评论
Does it light up at all when you first plug it into your Clamshell (to see if it's receiving power)? I actually use a Sandisk Cruzer Micro 8 GB (SDCZ6-8192-C11). On my Clamshell, it seemed to go in, but I eventually realized that it wasn't going in all the way since the Cruzer Micro wasn't showing any signs of even doing anything at all.
这个答案有帮助吗?
得分 0
4条评论:
It does light up briefly, but that's it.
完成的
Have you tried reformatting the flash drive in another Mac, with a partition scheme of APM? I don't like the Cruzer, myself, because there's an extra Windows-only partition on there you can't get rid of. Maybe that's what OS9 is choking on. I prefer the Kingston or Attache flash drives for that reason.
完成的
I assume that you're referring to the U3 partition? I suppose it could be a problem under OS 9. While mine has worked perfectly under OS X, it apparently hasn't been so perfect for others. Check out this Macworld article for more info.
完成的
(Note to self: Comments seem to have no formatting...)
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
I've owned at least five 300 MHz clamshells and none of them had cd burning capability. All they had were CD ROM drives. The sole 366 MHz clamshell I've owned came with a DVDROM drive. No burning capability too.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,204
