跳转到主内容
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
20 个问题 查看全部
My hdmi port is broken and needs repair
I just want to know how much it would cost to get my hdmi port replaced before I send it in.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 37
2条评论
Anyone know a person or company that can replace my ps4 hdmi port
完成的
There's several here on ifixit that can do it. I do lots of them as well. You can contact any of the businesses here by clicking on their name and that will take you to their business listing where you can contact them.
完成的
添加一条评论
4个答案
已选择的解决方案
I've done a lot of these repairs and I'd be happy to take a look at yours. If you'd like a quote just click on the link under my profile name. It will take you to my IFIXIT business listing where you can learn more about us and find the link to our repair services page on our website.
Please let me know if you have any questions.
这个答案有帮助吗?
得分 9
46条评论:
my hdmi port is broken but not sure if that is the only problem.. although the ps4 does turn on
完成的
If your console turns on then you likely just have an HDMI port issue. It's possible that there are other problem as well though.
完成的
My ps4 turns on but doesn't show up
完成的
If it turns on and goes to the white light then you probably have an HDMI port problem.
完成的
My ps4 won't show show and it's not the cord
完成的
显示更多的41条评论
添加一条评论
The best way to replace the port is with a hot-air rework station, an ultra fine point soldering iron, and a high-powered microscope.
Here are the steps:
1) Remove the motherboard from the case, and clean the old thermal paste.
2) Apply flux to the existing port connections, then begin heating the posts and pins evenly with the rework station.
3) Once the existing solder has reached its melting point, use tweezers to SLOWLY remove the old port.
4) Now clean the board, and inspect for any damaged traces (depending on the severity of the port damage)
5) Now position the new port in place, add solder to the posts to hold it in place, apply flux to the pins, and then individually solder each pin to the motherboard using the soldering iron.
Providing you followed the steps, the unit will boot like normal once you re-assemble.
That said, if anyone needs any assistance (or advice) with their repair, please give us a call anytime!
We are more than happy to help.
Cordially,
这个答案有帮助吗?
得分 8
5条评论:
Thank u this is the best answer this really helps a lot
完成的
How do I call u it really need help with a few pointers
完成的
I actually found your number and I will be calling u tomorrow thank you for the tips
完成的
what is there phone number?
完成的
Ps4 turns on but goes to black screen
完成的
添加一条评论
Can any one fix my ps4 hdmi port
这个答案有帮助吗?
得分 0
添加一条评论
i am able to do this job
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Devin Cannon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 45,150
