跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Battery won't budge - suggestions?
I'm trying to replace the battery on an iPod 5G video (30GB). I got the case open (after some drama - I think the plastic got brittle over the last eight years...) but the battery won't budge. The directions say that the battery will come loose with some prying, but mine seems fused to the case. I'm afraid I'm starting to bend the case itself, and I'm worried I'll damage the ribbon cable that goes under the battery.
A friend suggested using a heat gun to melt the glue, but using a heat gun on a battery seems like a bad idea.
Ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
ellard, the battery is fastened with some double sided tape. You will have to pry it out. Yes, it may take considerable force, but there is no other way to do it. you may tear the hold switch/ audio jack flex, but you can replace this fairly easy as well.
这个答案有帮助吗?
得分 2
2条评论:
After your suggestion, I went back and got a bigger lever, and indeed the battery did come out. I was able to preserve the hold switch cable by gently teasing it apart from the mass of glue.
I'm letting the whole thing charge completely before testing it out, but it rebooted when I attached the charger and is flashing the charging icon, so I am optimistic.
Thanks!
完成的
Good job. Sometimes it just needs an extra bit of oomph!
完成的
添加一条评论
添加你的答案
ellard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 166
