跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
125 个问题 查看全部
问题已关闭
touch screen not working when I lay new screen down?
installed new digitizer, tested works good, but as soon as i lay the screen down, the touch stops working. help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
also, there are no tears or anything in the cables
完成的
添加一条评论
3个答案
最有帮助的答案
If it's a copy screen you will no this as on the original the inside border bronze the copy's are sliver..
The copy's have a tendency to short out against the frame check this out could be the same ideasolution to phantom/ghost touches ipad air
这个答案有帮助吗?
得分 1
4条评论:
Wow con, you are seriously a genius. It hasn't worked yet, but I will try it now. This is the only answer that has made sense, and you have helped me in the past. Thanks
完成的
So it totally! Worked thanks so much...BUT, now the home button isnt working, and double checked the connection and tried another home button :/
完成的
Mmmmm try a home flex from a different vendor if that doesn't work then it could be s problem with the board
完成的
its so weird, both cables i think are fine and there is no apparent damage to the board. i also noticed if i push on one side of the screen/frame, its turns the phone on and off. ugh
完成的
添加一条评论
Glad that helped
Have you tried two home button flexes and they arnt working?
这个答案有帮助吗?
得分 0
1条评论:
yes :/
im not sure what is going on
完成的
添加一条评论
Check C6505. Worked for me.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 1,849
