跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
Left Side of LCD has shadows/lines after screen repair?
Hey guys,
I've had this issue once or twice now and basically after replacing the glass on an iPad Air, the left side of the LCD has weird shadows going down the side of it. Not sure what caused it as I'm always very careful throughout the repair (expensive devices!) but just wanted to check with the iFixit community to see if anyone had some insight here.
I did a quick search and read about possible firmware issues, although this seemed to be for a different issue than what I'm having.
I'll try to get a picture uploaded soon.
Thanks for any help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
I also have this issue. Replaced the LCD and the lines/shadows are still present. Any insight would be appreciated.
这个答案有帮助吗?
得分 1
添加一条评论
Hello loosen the screws this puts pressure on the lcd when to tight and can cause shadows hope this helps..
If screen was grand before fitting and there's a problem after its never firmware issues but the repairs fault
这个答案有帮助吗?
得分 0
添加一条评论
I have the same defuse squarish pattern up the entire left side. I sent it back thinking it was a manufactures defect only to have a replacement one do the same thing. It has no pressure behind it. It's not even screwed down. Appreciate any help.
这个答案有帮助吗?
得分 0
添加一条评论
Had the same issue, also still present when the screws were not secured. I was thinking it could have been the connector ribbon as I pulled the edge up a bit when trying to take the connector plate off it (I didn't rip the connector but it just pealed at bit from the connection piece), but not certain.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jon 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 19
总计 1,718
