跳转到主内容
The ASUS PadFone X is a revolutionary 5-inch Full-HD LTE Android smartphone that can be easily transformed into a 9-inch Full-HD LTE Tablet. ASUS released the device in June of 2014 and is identified by model number T00D.
16 个问题 查看全部
Why does my WIFI keep disconnecting?
The WIFI on my Padfone keeps disconnecting every time I stop using the phone for a few minutes. When I go to recheck my phone some minutes later, the WIFI is not connected. What could cause this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
You should first check to see that you have a strong WIFI signal. If you have verified this, most likely you need to edit your WIFI settings on the phone. Swipe the top of the screen down, and click on the settings button that now appears in the upper right corner. Select 'WIFI' and then choose 'Advanced'. Uncheck the option for the WIFI to disconnect when the phone enters sleep mode. This should solve your issue and prevent your signal from consistently dropping.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrew Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 409
