跳转到主内容
加入维修社区 - 创建账户
Button makes electronic "click" sound when pressed
Here's a weird one -- I've got a 14" iBook G4 that makes a subtle electronic click sound when the button is pressed. It also makes this sound when the space to the LEFT of the button is pressed, like just pressing on the plastic of the topcase is triggering it as well. Very odd, I know. The sound almost sounds intentional, as if it's supposed to happen, and it's very subtle and high pitch, like two pieces of glass or metal lightly tapping. It's kind of pleasant, actually. It's definitely an electronic sound.
Anyway, I've had a few machines do this over the last couple years, and while it's not a huge horrible problem, it would be interesting to know what causes it. The machine has a fresh OS, so it's not a tweak to the button settings, etc.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Does it sound like an HDD sound?
完成的
when you say "button", are you talking about the power button, or the trackpad button?
完成的
添加一条评论
4个答案
已选择的解决方案
The way the power button is installed I would suspect a mechanical rubbing and release is the cause of the click. Pressing on the top case would have a similar result I should think. Ralph
这个答案有帮助吗?
得分 1
1条评论:
He says it's definitely mechanical
完成的
添加一条评论
If you look in System Preferences>Track Pad>Clicker you'll find the solution. Clicks like the clickwheel on an ipod. OR not, depends on the setting.
这个答案有帮助吗?
得分 1
1条评论:
That's a good thought, but I remember checking that, and it wasn't it. The clicking didn't happen all the time. Since I know it wasn't the hard drive either, I can only assume it was some kind of electrical flaw in the topcase. Ah well, I'm not going to lose any more sleep over it unless I come across a similar machine.
完成的
添加一条评论
Maybe a simple PRAM reset will work.
这个答案有帮助吗?
得分 0
6条评论:
Tried that, good idea though.
完成的
If it's definately hard drive then verify/repair/replace
完成的
I'm not convinced...it makes the sound when the button is pressed...I've never known hard drives to make a distinct sound on command.
完成的
I have a feeling that he needs to open it up and take a look.
完成的
Sorry, I meant to say it's definitely NOT the hard drive, but I forgot the "not". :-) It was a minor issue and I sold the machine, so I'll have to wait for the next one to solve the mystery. Thanks for the brainstorming though!
完成的
显示更多的1条评论
添加一条评论
Now that my trackpad stopped clicking by itself, I'm not sure what's going on. It seems the button to select" clicker" in system preferences enables the trackpad to behave like the select button below it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rdklinc 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 48
总计 2,387
