跳转到主内容
加入维修社区 - 创建账户
Manufactured by JAKKS Pacific, these toy night vision goggles feature real night vision and video recording capabilities. Repairs will require screwdrivers and prying tools,and some repairs will require replacement pieces.
Why won't my goggles turn on?
When I try to turn on my Spy Net goggles, nothing happens. The device was working fine yesterday, but it seems like everything on the device just stopped working. I can't see anything on the screen inside, and the buttons don't even make the "beep" sound that they make when the device is on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
If you’re getting absolutely no response from the device, the most common answer would be that the batteries are dead. You can access the batteries by unscrewing the back panel of the device. If the batteries are not dead, then the problem must with the internal components of the device.
This could also be due to bad connection of the wiring that gives power to the device from the batteries. The wires might be severed or detached from their terminals. Check out this troubleshooting page for more information.
One last reason for the device not responding could be due to water damage to its critical components. This does not means that the device had to be completely submerged in a pool for water damage to occur, but this could have also happened if the device was left in a humid setting, in mist, etc. There are some remedies that might be of use if the device was not completely submerged that can be found here.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Justin Diehl 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 13
总计 4,471
