跳转到主内容
Cannot boot to new SSD
I replaced my existing hard drive with a new Crucial MX100 256GB SSD. Had no problems installing the SSD and installed OS X Yosemite via usb key.
Problem I have is cannot boot to this SSD at all. I tried setting it as the startup disk but it doesn't appear in the list of disks.
But I checked with with Disk Utility and it's mounted. I ran a verify disk and no errors where found. I also erased it and set it to Mac OS Extended (Journaled).
But still cannot boot
Update
Once I create a Gui partition table and reboot in recovery mode, I was able to install to my SSD.
Thanks for all the help :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Here's a screen shot of what I see in Disk Utility (sorry about the spotlight search bar)
http://i199.photobucket.com/albums/aa19/...
完成的
添加一条评论
1个答案
已选择的解决方案
Should be System Prefs->Startup Disk->Select Yosemite then tap Restart.
Alternately safe boot, or, boot to restore partition (R boot), choose Yosemite from there.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
2条评论:
Thanks machead3, but I don't see my new SSD in the list of Startup Disks. I did create a Guid partition in Disk Utility. Here's a screen shot of what I see in Disk Utility (sorry about the spotlight search bar)
完成的
You may have the SATA cable problem.
完成的
添加一条评论
添加你的答案
habs33 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 860
