跳转到主内容
加入维修社区 - 创建账户
The Lenovo IdeaPad U350 was released in 2009 as a low-cost, thin, light laptop. It shipped with Windows Vista Home Premium (64-bit) or Ubuntu and features a 13.3" display.
Why aren't some of the keys on my laptop working?
Recently some of the keys on my IdeaPad U350's keyboard have stopped working, but most of them are still functioning just fine. Does anyone have any idea what could cause this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
1条评论
When i received my laptop all of keys on the keyboard worked perfectly fine, but one day half of them stopped working. Now I have to dd n extra keyboard so i can use my laptop. Why is that?
完成的
添加一条评论
2个答案
最有帮助的答案
There are a few things which could cause this issue. The most likely cause is a broken keyboard, which will need to be replaced. Another possibility is that the ribbon cable connecting the keyboard to the motherboard is making an incomplete connection. Re-connecting it may fix the issue. Finally, the least-likely possibility is that there's a problem with your motherboard.
这个答案有帮助吗?
得分 4
2条评论:
I have attached another external keyboard but same problem as it is
完成的
Was the keyboard that you attached working on a smart tv or a different PC? (or any peripheral that supports an external keyboard)
完成的
添加一条评论
It's possible you just have a bit of dirt, lint, or some other contaminant underneath a few of the keys. Try blowing them out with compressed air before you look into replacing keyboards or other components. If the individual keys can be removed on your particular model, carefully pry them up and wipe down the contacts with isopropyl alcohol. Allow them to dry before you reassemble. If neither of those things helps, look into some of the culprits that James mentioned.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jason Sweeney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 10,922
