跳转到主内容
Model A1320 / 8 or 16 GB capacity
156 个问题 查看全部
How can you tell if it's 8 or 16 GB capacity?
Model A-1320 EMC No2317
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
What if you don't have a charger to turn it on? How do you know then?
完成的
添加一条评论
5个答案
已选择的解决方案
In the main menu, scroll down to settings
From settings select About
这个答案有帮助吗?
得分 4
1条评论:
Go to the iPod icon in FINDER. Right click and select GET INFO. Look at capacity to determine 8 GB or 16 GB.
完成的
添加一条评论
Model A 1320 EMC no.2317 Is it 8 or 16GB capacity
这个答案有帮助吗?
得分 1
1条评论:
Have yo checked any of the above answers yet? The numbers your have are only confirming that it is September 9, 2009 Disc Date: September 1, 2010
Order No: MC031LL/A* Model No: A1320 (EMC 2317)
Subfamily: iPod nano 5th Gen Model ID: None
Std RAM: N/A Std VRAM: N/A
Std Storage: 8 GB, 16 GB
But they will not help you with this task.
完成的
添加一条评论
Look on the back of iPod >?
这个答案有帮助吗?
得分 0
添加一条评论
I thought most iPods had their capacity inscribed on the back. You can also connect your iPod to your computer and see how much memory you have. It will probably tell you a smaller number than 8 or 16, because you can only use a portion of those numbers for storage.
这个答案有帮助吗?
得分 0
添加一条评论
My ipod not showing charging
这个答案有帮助吗?
得分 0
1条评论:
I've charged it about an hour it won't go to settings,or I don't know where to find it. It stays on music cover flow artist songs videos TV shows I can't get it to do what it's supposed to do. Especially charge
完成的
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 28
总计 31,945
