跳转到主内容
Released in 2008, part of the Air Warrior line of Buzz Bee foam dart guns. Features include a large ammo capacity and an automatic firing mode. Repair in most cases is easy, requiring only simple tools.
5 个问题 查看全部
How do I stop darts from getting stuck and jamming the gun?
I've noticed that when I fire and use my dart gun for extended periods of time darts have a tendency to get stuck near the tip of the gun rather than firing out normally. Is this due to a defect in how the gun was built or some other issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I have a Nerf Ultra Speed and for some reason the bullets are not coming out of the mag and making it jamming and shooting slowly, why is that?
完成的
添加一条评论
4个答案
最有帮助的答案
If your darts get stuck, it might be your gun or the darts themselves. Sometimes after being fired many times and successfully hitting many targets, the darts will get bent or weakened, this will jam the gun and they might get stuck. Check out the Troubleshooting Page for more help!
这个答案有帮助吗?
得分 1
2条评论:
It is actually due to not pulling the trigger hard enough. When you pull the trigger it pushes the bullet into the powered barrel so if you half pulpit it gets jammed between the ammo clip and the barrel!
完成的
You might have to use a special thingamajig. Moira is right.
The darts might be chewed up or damaged from another gun.
完成的
添加一条评论
I think that anonymous is wrong because that if you only pull the trigger hard, it only shoots. It has nothing to do with gun jams. Check the bullets and the gun, Garmsen.
这个答案有帮助吗?
得分 1
添加一条评论
if you see a very small button on the side of your nerf gun, press it and $!^& the gun and it should unstuck
这个答案有帮助吗?
得分 1
添加一条评论
my nerf gun was stuck bc it is a xshot zuru gun with balls and then i tryed what soyboy told us and it works thx soyboy
这个答案有帮助吗?
得分 0
1条评论:
my gun did the same thing
完成的
添加一条评论
添加你的答案
Reed Garmsen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 56
总计 15,483
