跳转到主内容
The Dodge Journey is a mid-size crossover SUV manufactured and marketed by FCA's Dodge brand since model year 2009, with a mild facelift for 2011 model-year.
27 个问题 查看全部
RH brake lamp still out after bulb replacement
My right side brake lamp was not working. I checked the bulb, and the glass was visibly burned on the inside, and appeared to need replacement. However, after replacement, the brake light on that side still does not work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Since the brake lamp on only one side is not working, it should not be a fuse. You may want to check the socket that the bulb fits into - it includes some circuitry that can be burnt out as well. An easy way to check is to swap the socket with the side that works. If the light then works, you know it is the socket that is bad. If it still does not work, another possibility is that there is a computer system code - yes the lights are controlled by a computer in this car, and if there was a short detected (which can happen in rare cases when the bulb burns out in a particluar way), the computer will have disabled the power supply circuit. In this case, the memory needs to be cleared. A dealership can clear it with a manufacturer's scan tool, but that may be costly. An alternative may be to disconnect the battery for 30 minutes. This will clear other memory, including radio presets, but may solve your problem. If it does not, it may need professional diagnosis to identify other possilbe wiring issues.
See the 2011 Dodge Journey Troubleshooting page for more more helpful information on this topic.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 16
总计 372
