跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
201 个问题 查看全部
water damage help need to b fixed
How do you Fix an HTC m8 . I dropped it in the toilet . After a few hours my front camera completely stopped working then I put it in rice for over 8 hours , now if you shake the phone you can hear the water whooshing around in it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Same problem here can you help me :(
完成的
eiadajam, skip the rice nonsense. Disassemble your phone, clean every part with high grade (90%+) isopropyl alcohol, replace the battery and re-evaluate.
完成的
添加一条评论
2个答案
最有帮助的答案
Any components of your phone can work now?
You should have take it apart and then put it in rice. As my experience to tear down HTC One M8, the impermeability of M8 is good, so if you don't take it apart, the rice can't absorb the water inside, and the water can't evaporate.
You missed the best time to save your phone, so now, take it apart, dry the water(don't use hair dryer directly, use rice, cloth and put it in air at first), and then assemble it to see if it can work.
I'm afraid you will face a heavy waterdamage problem.
这个答案有帮助吗?
得分 1
添加一条评论
My phone fell I water and I can't take it apart so I jus put it in rice but ion no how long to keep it in the rice
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jazzmine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,946
