跳转到主内容
Clothes dryer repair and support guides.
770 个问题 查看全部
Which part might need to be replaced?
Kitchen Aid gas dryer. When I start it I get the glow & flame. However, flame goes out after a few minutes. Could it be the gas solenoid?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Cause 1
Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won’t heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, we recommend that you replace them as a set.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
joe schmidt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 118
