跳转到主内容
A rotary tool made by the Dremel company. It is model number 395 and runs at 5000-35,000rpm.
7 个问题 查看全部
Why is my Device not turning on?
I plugged My MultiPro in and no matter what I do it will not turn on. The bit will not rotate and the device seems to not be getting power at all. Can this be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
1个答案
最有帮助的答案
Yes, this problem can be fixed. Ways in which you can fix your dremel and get it to power on are, Making sure the dremel is plugged in, make sure the brushes are properly cleaned, and make sure the stator wires are making a connection with the connector.
Dremel MultiPro 395 Troubleshooting
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matthew Satton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 2,101
