跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
Convert dead iMac to a Monitor?
I have a 2008 iMac, and unfortunately the logic board is dead. I already confirmed it's the logic board - the apple store took a look at the device. I wanted to give myself a project and try to convert this to a workable monitor - and primarily set it up to work with an external gaming console (Xbox, etc). Is this even possible? Is this even worth the effort or am I SOL? I hate seeing the Mac gather dust in the garage.
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Can you get a number of the LCD panel itself?
完成的
添加一条评论
2个答案
已选择的解决方案
The Answer I hope is yes. I have a controler board NT68676 2A 1256 which has vga hdmi and
dvi-d inputs with audio. a simple 4 button control board plus a cable to go between the controller and LCD panel cost around $30 from ebay.com cost me a bit more as I am in UK.
The above controller is normaly use for smaller panels and supplies 12v to power the inverter for the LCD panel. I asked the supplier if I could provide the 24v for the iMac inverter would his controller board be able to handle the signal side of things, he's said it would.
I am looking with no luck yet to find the pinout for the power supply as from the work done on earlier versions G5 and 20 inch it would seem I will have to ground 1 pin on power supply to switch it on. if anyone knows the answer or has already done this would be most grateful if you could share it.
Update
I have today found this pinout from a power supply in the off state but possibly faulty, so if any one could supply pin out for the on state would be great
PIN V
1 GND
2 +12
3
4 4
5
6 GND
7 GND
8 +12
9 +12
10 +12
11
12 GND
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
If you are talented and experienced with small electronics it is feasible. 'Personally - I would sell the machine as is on Ebay take that $ and put it towards a working x-box.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ed Hsiu 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 11
总计 1,888
