跳转到主内容
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor
106 个问题 查看全部
问题已关闭
Where to find a replacement optical drive
Looks like my drive is broken. I'm looking to replace it. The closest replacement I have found is this drive from SilverStone http://www.amazon.com/SilverStone-SOD01-... and this http://www.madeinchina.com/2722501/S3532...
Is there a better source than these? OWC doesn't seem to have any SATA versions of the optical drive.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
That looks like it's true at the moment, however stock changes so check back some other time and they might have it. However you probably want to get this part soon, so check here, that's probably the second most reliable Mac e-store there is. You'll find links there also on how to install it and videos to guide you, however right here is iFixit's step-by-step installation guide].
这个答案有帮助吗?
得分 0
添加一条评论
How about the part from
here? (parts button on the right).
If this answer is acceptable please return and mark it.
Good Luck,
N.
这个答案有帮助吗?
得分 0
1条评论:
You should double check that link machead
完成的
添加一条评论
Unless I missed it they don't have an optical drive. Just the hd enclosure for the optical drive bay which I already ordered by mistake. I would love it I'd iFixit had the optical drive. Then I could use my credit from te enclosure return.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 2,448
