跳转到主内容
加入维修社区 - 创建账户
型号A1288,闪存容量:8、16及32GB
iPod won't charge, not battery problem
I recently changed my battery because my iPod would not charge, now it still wont charge or connect to Itunes. It pretty much just doesnt even register that it is connected. Please HELP!!! Could it be a problem inside the iPod where it connects to the cord???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
I noticed you never got an answer to this. Are you still having this problem?
完成的
EmmaPunkPrincess, did you get it fixed?
完成的
Have you tried a different connecting USB cord?
Did you or Apple replace the battery?
完成的
添加一条评论
1个答案
最有帮助的答案
I'm guessing you have an issue with your dock connector. Check it again to make sure that all of your cables and connectors are seated properly. If that still doesn't work, you may need to replace the dock connector.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
EmmaPunkPrincess 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,033
