Why won't my computer turn on?
My computer will not power on after pressing the power button. It remains off, even if the power cable is plugged in to an outlet.
Nathan Jansen, start by checking the AC adapter. Use a multimeter and ensure that you have the proper output. If you do, check the DC adapter on your laptop. Make sure that it is properly connected and that you have current going to the board. If you do and it still does not come on, check the power switch flex and make sure that it is working properly.
这个答案有帮助吗?
@oldturkey03 nice the power switch flex = that is working properly. what is the other swolution can you help me
This may be caused by a bad power supply. The AC adapter may need to be tested for defectiveness. The output and DC adapter may also need to be checked.
这个答案有帮助吗?
@Jade Kim, how is this different from the first answer?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 303
