跳转到主内容
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
52 个问题 查看全部
问题已关闭
car stalled as I was leaving parking lot will not restart
Ok so i have a 1993 Honda Civic DX with automatic limited slip transmission. So i was leaving parking lot car stalled and when i tried to restart Nothing. Had to get tow truck. took to my local auto shop. the stated that it was my ECM that mine was blown. And that it was not fuel pump or timing belt and that Cylinder one was showing no compression and that was flooded. So ordered a ECM online and replaced it. With no luck Auto shop then stated that it might be Distributor. So I towed my car home due to that it was obvious they had no clue what they were doing and i didnt have the time to wait so then i Replaced distributor and checked spark plugs and all fuses and starter. still no spark. What should i do now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
If a repair shop told you didn't have compression in a cylinder and needed an ECM they are either brain dead or blowing smoke up your ***! Compression in cylinders is mechanical issue only and ECM is electrical. "no compression" would mean total failure of piston and you have scrap metal for a motor and would have sounded like a wrench got jammed in your motor right before the abrupt halt to your journey! That being said it leaves the other two components to an engine running, which are gas and electrical. I have no idea how knowledgeable you are so I assume none just to be sure not to overlook the simple things. Process of elimination is the best way i know of for me. You said no spark but just in case you just meant wont start an easy check is to start with is take off one plug wire and lay it next to a solid metal spot close so that a spark can jump from the plug to the metal. This is best done at night in as dark a spot as you can. Have someone turn key as if starting car while you watch the plug. If a spark happens then its gas or timing issue. If no spark then it gets more complicated and its a matter of checking parts for the reason. To check if its gas get some starter fluid and spray some in through air intake and try to start it and if it starts then dies its gas problem of some sort. If a spark happens in a cylinder with gas in it at right time there will be some action! Those are my suggestions for a starting point for what they are worth. Good luck and let me know what happens or update if its fixed already.
这个答案有帮助吗?
得分 1
添加一条评论
Just in case, check the tail pipe for a potato stuck on the end or something stuffed up the pipe.
这个答案有帮助吗?
得分 0
添加一条评论
I have a 1995 Honda Civic with no compression. Turned out to be the control module in the distributor. No spark meant raw fuel being dumped in the cylinders diluting the oil. No oil in the cylinders means no compression. I replaced the distributor and it fired right up. I also changed the oil because of the fuel being mixed in with it. Runs great!
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 298
