跳转到主内容
The first tablet from Acer's Iconia Tab B1 family, Acer Iconia Tab B1-A71 was announced in January 2013.
21 个问题 查看全部
Why is my picture in negative
My acer tablet has not been dropped or damaged to my knowledge. When I turn it on, the colour is all in negative. I've tried resetting and even just a simple turn off and on. Does anyone know if this can be sorted or does it need to be repaired by a professional.
Any help will be grateful
Thankyou
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论:
same goes to me. i didnt dropped it and when i turned it on after charging all the pictures turn negative.
完成的
have you tried to go to settings - Accessibility - Negative Colors
完成的
Yes I have tried setting_accessibility. But could not fine negative colors....
完成的
添加一条评论
2个答案
You will need to turn of color inversion. Go to settings, click accessibility, scroll to the bottom, then click color inversion. That should fix it!
这个答案有帮助吗?
得分 0
添加一条评论
Most likely you have cracked resistor at lcd flex cable
You need to replace it with working one
https://imgur.com/a/3W99K
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gemma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,263
