跳转到主内容
External HDD Enclosure Not Mounting
Hi,
A few days ago I dropped my macbook, thus I think I broke the HDD. I bought an enclosure to accees my data on another mac. The hdd fits perfectly but I cannot get any mac or pc to see the external disc. The light is on when I plug it in the usb port but nothing happens. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Sadly, it does sound like the drive has died.
If you can't see it from another working Mac then either the drive is bad or the case is if its new. Given the fact you dropped your system its most likely the drive is gone. Sorry ;-{
这个答案有帮助吗?
得分 0
2条评论:
Thanks, Dan. My macbook still turns on and loads the apple logo so I thought the drive should still be ok-ish. Also when I plug the enclosure into my iMac I can hear it spinning. :S Would a specialist be able to recover the lost files?
完成的
Thats a good sign the Apple logo is appearing. As to savaging your files from your bad HD. There are labs which can repair the drive so if possible the data can be saved. I must warn you this is very expensive and its still a bit of a gamble if the files (some) can be saved. Google data recover services to see if you can find one close to to you. Here in the states there are a few good ones if you feel you need to send it out.
完成的
添加一条评论
添加你的答案
Luka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 70
