跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
20 个问题 查看全部
Screen jumping with new digitizer/glass
I have replaced a client's iPad air glass/digitizer with a new one and it tested fine before closing up. Once the internal protective sheet and adhesive were removed and the glass pressed down, the screen takes on a life of its own.
I have since tried another glass panel and had the same issues.
This time I was able to narrow down the cause to the upper folded ribbon for the touch interface (you will recall there are three ribbons and two plugs, the top one is the culprit).
I have NOT folder these ribbons flat, they are stuck to the screen in the same location/depth as the original ones were...
(I am am an experienced fitter, well into 3 figures on ipads and phones etc. but this is only the 3rd Air we have had...)
Please help!
Cheers,
Marc
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
I am having the same problem and have used 3 different digis. Would love a fix
完成的
添加一条评论
3个答案
最有帮助的答案
Here is your solution -
solution to phantom/ghost touches ipad air
这个答案有帮助吗?
得分 2
添加一条评论
Hi there first this is make sure you haven't been any pins on the board were the screen plugs in..
Now here is a pic of the cables these should be lifted up off the glass and not stuck to the glass as there is a little gap just beside the frame were they slot in make sure you haven't the cables crushed between the glass and frame
这个答案有帮助吗?
得分 0
添加一条评论
Pinching the flex can definitely happen when installing these screens, also we had a bad batch of about 3 faulty screens when we first started doing these. con is right, the flex needs to not be resting on the glass and fed through the gap on the frame where the flex goes. Either pinched flex or faulty parts I would say.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 28
总计 13,428
