跳转到主内容
加入维修社区 - 创建账户
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
Hard drive replacement
I'm replacing the hard drive. When I try to lift the top case off there is a wire attached to the left side. Short black wire, I'm guessing that it has to do with the left speaker, ground wire, wifi connector or whatever. Prevents me from folding the keyboard back. Can I remove this? If so then how? Please see photo... wire is shown left of center and sightly up from center.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Should be image attached now.
完成的
Got it! The microphone had stuck to the top case. Thanks for your input.
完成的
添加一条评论
4个答案
最有帮助的答案
I don't think you need to tamper with the keyboard in this situation it should come up with the housing around it. I have listed a similar model macbook pro below, its not the exact same but it does have the superdrive in the front like yours.
Check out this guide:
MacBook Pro 15" Core 2 Duo型号A1211 硬盘更换
There should be a ribbon cable holding down the keyboard.
Supply a picture if you are still having trouble... This will help us help you.
Good Luck!
-Varsity
这个答案有帮助吗?
得分 1
添加一条评论
I should have said I am struggling with the upper case. As you can see from the photo the wire is attached to the upper case ( far left edge of upper case, left and up from center in the photo) inside of a small black rubber projection.
Thanks for your response.
Bob
这个答案有帮助吗?
得分 0
1条评论:
You keep referring to a photo, but have not posted one. please do so.
完成的
添加一条评论
The Microphone Is just stuck to the top case, sometimes went the rubber gets warm, it gets sticky.. it is by no means attached to the top case. just grab it, it will pop right off. it goes in the little cutout part of the left speaker assembly just below it..
这个答案有帮助吗?
得分 0
添加一条评论
I found the HD replacement instructions for the model A1151, however my model is A1261 according to MacTracker. Was there a (installation) diff. between the early 2008 model and the late 2008 model
这个答案有帮助吗?
得分 0
1条评论:
Please start a new question. Thanks
完成的
添加一条评论
添加你的答案
Robert Hanson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 6,012
