跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
Can I use the Seagate Momentus XT 500GB hybrid HDD?
I have just recived my new i7 MBP, but since I got it through work, I could not upgrade to the 7200 RPM HDD so I am stuck with the 5400 RPM 500GB, can I use the Seagate Momentus XT 500GB instead ??
Regards Christoffer
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
12个答案
已选择的解决方案
That's a hot looking drive and I see no reason for it not to work. http://www.overclockersclub.com/reviews/...
这个答案有帮助吗?
得分 2
2条评论:
Agreed
完成的
Interesting drive + Ralph
完成的
添加一条评论
I can't speak for the late 2010 MBP 15" specifically, since I don't own one. However, I am using this exact product in my MacBook Pro Santa Rosa, and I have a co-worker that's using it on his 13" MBP Unibody.
So far, both of us have been using our drives for approximately a month. There have been no serious problems, and my co-worker swears by it -- he's a programmer, and everything that he uses the drive for is super-fast. My own experience is almost as good, given how fast the system / Safari / Mail / and other frequently-used applications boot up. However, I was hopeful that Photoshop wouldn't take forever and a half* to boot up, like it did with my previous drive. Even though I use PS frequently, the drive hasn't put the software on the SSD portion of the drive -- yet. Apparently, this thing learns from users and puts the often-run programs on the SSD, so I'm still hoping that it might switch over PS one fine day.
I have encountered a rogue spinning beach ball of death a couple of times. But I don't know if that was due to the drive, or if that would have happened regardless of what HD was inside the computer. Nothing too serious though.
I also haven't broken it yet. I take my machine pretty much everywhere I go, even to some not-so-friendly places. The Momentus XT keeps on tickin'.
* I've come to realize that "forever and a half" is relative. Last night I rebooted my wife's XP machine and I nearly started banging my head against the wall -- it was that slow. Eventually I just let it run its course while I did stuff on my machine. Photoshop probably takes all of 20 seconds to boot up, but it would be nice if that number was less than 5.
这个答案有帮助吗?
得分 1
2条评论:
Once you go SSD, you can never go back. (Or in this case, partially SSD)
完成的
I heartily concur! The only way this drive's coming out my computer is if it breaks and I have to replace it.
完成的
添加一条评论
well.. That was also my conclusion, just want to be sure before buying some 150 dollars HDD :D - but thanks !
这个答案有帮助吗?
得分 0
2条评论:
no problem
完成的
Please return and mark Myers answer accepted! This will clear our board of "unaswered questions".
完成的
添加一条评论
Did you buy it? Does it work as expected?
这个答案有帮助吗?
得分 0
2条评论:
Hello.. No, I haven't brought it yet,- was a little short on money, so wont be before some time in September.. :(
完成的
添加一条评论
I'd recommend first checking the spin down problems with this drive:
http://forums.seagate.com/t5/Momentus-XT...
这个答案有帮助吗?
得分 0
添加一条评论
I read some reviews saying that they were having beach balls or some problems using that drive and the MBP
这个答案有帮助吗?
得分 0
添加一条评论
Yea, tested it for a couple of weeks in my mid 2010 mbp. I had massiv beachball problems all the time. i recome to not buy this hd if u are going to use it in a mac.
这个答案有帮助吗?
得分 0
添加一条评论
@Andreas Schnetzer
How do you make sure the beachball is hard disk issues?
For me the only issue I had is that the drive was unable to boot with the latest EFI firmware for my MacBook Pro (Mid-2009). Once I downgraded it to the previous version (1.6) it started to work perfectly (that was months ago, so it's a long experiment). Maybe you're using Snow Leopard? because I remember I read some threads in Seagate/Apple forums about the HD not working properly with Snow Leopard.
这个答案有帮助吗?
得分 0
添加一条评论
Well, i switched back to a normal 7200rpm 2,5 Harddisk last weekend and since then the Beachball Issue is gone, so i asume the Momentus XT was the Problem :)
Maybe i update to the new firmware and give it another try in the Holidays.
cheers
这个答案有帮助吗?
得分 0
添加一条评论
Right. SD24 was released recently. There are many positive feedbacks from a lot of Mac users in Seagate forums.
这个答案有帮助吗?
得分 0
添加一条评论
I just installed this drive on my Mid 2009 MBP [core 2 duo] with no issues. I simply followed this guide and viola.
MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement
1 Note: The battery does not need to be removed during installation, so you can skip that part.
- Also, I haven't updated to the newest firmware, so I'm not sure if that will help. I'll let you know if I have any issues.
Cheers
这个答案有帮助吗?
得分 0
添加一条评论
Here is the official Seagate Momentus XT SD26 firmware update. It helps with compatibility on Macintosh computers. SD26 is the latest version of the drive's firmware as of the end of August, 2011.
Windows version (easiest):
http://www.sendspace.com/file/mhlkbf
Bootable iso version:
http://www.sendspace.com/file/rifiz5
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ChristofferBB 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 25
总计 22,359
