跳转到主内容
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
Mother board getting hot upon reassembly.
I disassembled my PS4 controller to paint it. Reassembled correctly from every video ive watch but when I connect the battery the spot to the left of it gets hot and the controller wont cut on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
4条评论
did you check if you got any paint etc. on the logic board? Heat on a circuit board is usually caused by shorted out components. Do not use your joystick until you find the cause for the overheating, this may cause more damage.
完成的
The mother baord was no where near the painting.
完成的
Found the problem, the touch pad connection wasn't good. Blew it out and wiped it off and it's ok now.
完成的
My TouchPad works fine but the section of the board where the buttons go still gets pretty hot, not sure what to do
完成的
添加一条评论
13个答案
最有帮助的答案
I had the same issue and for me it was an issue with the touch pad ribbon cable being disconnected. The one in the actual touch pad not the connection to the motherboard.
So open up the touch pad and check if the connection in there sits correctly.
这个答案有帮助吗?
得分 7
1条评论:
For me it was exactly the same. At first I missunderstood what is meant with the ribbon cable at the touchpad. I always looked at the ribbon cable that comes from the touchpad and goes into the logic board. If you don't really know what to do, look at this video I found. It helped for me: https://youtu.be/MUzqnf7nqsE
完成的
添加一条评论
I had the same problem when reassembling my dualshock 4...
The touchpad ribbon cable turned out to be the source of the problem...
Solved by detaching and re attaching...
这个答案有帮助吗?
得分 2
2条评论:
That didn't work for me I tried it twice
完成的
it dint work for me at first but then i tried moving the other end of the touchpad cable and bam it started working.
完成的
添加一条评论
I've got the same problem, and upon closer inspection, I've noticed that the power management chip (BD9200) gets extremely hot, way past what should be normal, I'd say easily above 100°c within seconds of plugging it in.
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem with my controller. I replaced the thumbsticks with the ones from the Xbox One, and after I plugged the battery in, the motherboard was getting hot even when the controller was turned off. I think something has been damaged unfortunately.
MorbidStix offers replacement parts for Dualshock 4 controllers, I think buying a new motherboard is your best chance.
这个答案有帮助吗?
得分 0
5条评论:
Read my comment above. Make sure the touch pad ribbon cable is wiped and blow out where you plug it in. I just wiped it off with my finger and opened the ribbon spot then blew it out and put the ribbon in there and closed it. Works fine now.
完成的
Worked like a charm, thanks bro !!!!!
完成的
I wiped the ribbon for the the touch pad and assembled it several times but the motherboard still gets extremely hot when the battery gets connected.
Please help!!!!
完成的
Cool, thanks. I'll try it. However my controller does work, but the battery drains very fast and I think it has something to do with the circuitboard getting hot. Could please give an update if you experience the same problem?
完成的
Mine didn't work when I had the problem but works fine from what ive noticed so far.
完成的
添加一条评论
I've had the same problem but blowing the touch pad doesn't fix it it just has no signs of working
这个答案有帮助吗?
得分 0
添加一条评论
i have the same problem! .. what i can do now ?
这个答案有帮助吗?
得分 0
添加一条评论
Does any one know how to take out the circuit board?
这个答案有帮助吗?
得分 0
添加一条评论
My problem is itry to cut 2 engine which use for vibration after that my controller not working and mother board have some heat
这个答案有帮助吗?
得分 0
添加一条评论
The mother bored in my ps4 controller is over heating every time I put the battery in ? Help
这个答案有帮助吗?
得分 0
添加一条评论
Thank you so much!! After hours searching the net for lights not turning on or not charging, I gave up thinking the controller broke. Luckly I gave one last try and searched for getting hot, which it was a bit, and found this!
I had disassembled the dualshock 4 to fix the triangle button which was getting stuck. After that the controller simply wouldn't work. With your help I just cleaned the flat cables a bit and it came right back to life :D
这个答案有帮助吗?
得分 0
3条评论:
How do you clean the cables?
完成的
I just used a clean cloth like those used to clean up TVs or glasses. However, I put it to charge and some days afterwards (I don't play much) it was not working again. I didn't bother opening it again as I have other controllers but I'll do it if I need this one.
完成的
Help me it won't work
完成的
添加一条评论
I have the same issue. After reassembling my ps4 controller, I noticed that once I pressed the touchpad in my controller discounted. It would not turn back on, or even light up, so I decided to press the reset button. This worked and my controller turned back on, but after pressing the touchpad once again my controller disconnected. I opened my controller and pulled all of the ribbons out and put them back in again. This did not work and my controller refuses to even light up now, even after pressing reset. Does anyone have any idea how to fix this, or know what has happened? All help is greatly appreciated :)
这个答案有帮助吗?
得分 0
添加一条评论
my ps4 dualshock won’t charge after heating the board with hot air gun for replacing the analog button with the new ones. The analog button work fine now but the controller itself only works when I plug it with usb.
Does anyone know how to fix it?
这个答案有帮助吗?
得分 0
1条评论:
Sounds like you over hearted a capacitor or a circuit. Next time only use a solder iron just for this purpose. A heat gun gets much too hot for small circuitry like a DS4 controller. The smaller the circuitry, the less heat that is required to desolder and ultimately damage tiny components.
完成的
添加一条评论
Dual shock 4 not on contact battery heat Mather board
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SU44K8 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 117
总计 14,169
